Torque Wrench Question
Old Jun 24, 2011 | 01:55 PM
lo-rider's Avatar
lo-rider
If you can convert inches to feet (divide by 12), you don't need a converter. But you DO need both a small 3/8"-drive (inch/pounds) plus a larger 1/2"-drive (foot/pounds) torque wrench to do routine maintenance on the Harley's. The beam-type is very cheap.
Old Jun 24, 2011 | 02:44 PM
krwould's Avatar
krwould
There seems to be confusion with in lbs and ft lbs with some people on the forum in earlier threads about this subject... make sure you have it correct or you will end up snapping off a bolt and multiply your problems rather quickly.
Old Jun 24, 2011 | 07:32 PM
babalu's Avatar
babalu
Originally Posted by Voony
I recall the service manual saying that the three bolts that have to be put back on the lower rocker cover have three different torque. But you might be correct for the inch-lbs...I found a unit converter online and 90 in-lbs is 7.5 ft-lb so I don't need another wrench!
you don't need an online converter, 12 inch lbs = 1 foot lb, just like 12 inches = 1 foot. the inch lb torque wrench is likely all you need if you're not removing the head bolts. i would've paid to see you put those rocker bolts back and torque it 90 foot lbs though... i thought maybe you were working on a tank.
Old Jun 24, 2011 | 08:04 PM
Voony's Avatar
Voony
:-) I'm glad you guys told me it was a bit odd. I just checked the service manual and it is indeed 90 - 120 IN-lbs.
Old Jun 24, 2011 | 08:08 PM
dickey's Avatar
dickey
Thanks guys! I'll get one from Home Depot (closest store to my home) and return it the next day eh eh.
When I worked for Home Depot back in the day, we referred to the return desk the "tool rental" dept.
Old Jun 24, 2011 | 08:23 PM
wilburz's Avatar
wilburz
+1 on the harbor freight. prolly less than 10 bucks. doesn't autozone give out tools with a deposit for free?
Old Jun 24, 2011 | 09:04 PM
sniperduce's Avatar
sniperduce
mine does on a valid credit card only....
Old Jun 25, 2011 | 12:30 AM
Voony's Avatar
Voony
That's always good to know!
kryingame
Jan 9, 2017 03:32 PM
baka1969
Jan 4, 2015 05:46 AM
baka1969
May 20, 2012 12:16 AM
lloydrtr
Nov 1, 2011 08:13 AM
dawg
Nov 1, 2006 01:54 PM
