Installing apes
Old Jul 22, 2011 | 01:03 PM
paulies 07's Avatar
paulies 07
Default Installing apes
I'm going to be installing new 16 inch apes on my WG, last time I used picture hanging wire
to drag the wiring thru the bars and lubed it with window cleaner, is there an easier way?
other than buying the bars pre wired. Thanks
Old Jul 22, 2011 | 01:54 PM
BillM's Avatar
BillM
Sounds like you have it covered there to me. After you run that wire down the bar from hole to hole...tie you a piece of strong string to it to use as a pull string. Cut another piece of the string the same length. When you go to pull another wire through, attach both pieces of string to the wire with tape and then pull. When you get it out the other end you have just put another pull string in the bars. Then you use the first piece of string for the 3rd wire just like you used the 2nd piece on the 2nd wire.
Old Jul 22, 2011 | 10:25 PM
paulies 07's Avatar
paulies 07
Hahahaha, that is an awesome idea, Thank You!
Old Jul 22, 2011 | 10:31 PM
8541hog's Avatar
8541hog
You're kidding right?
Old Jul 23, 2011 | 05:14 AM
Stubby3492's Avatar
Stubby3492
I just use a split shot fishing weight on the end of the string to get the string through. Since the wires already have a plastic sheath around them, I just tie the string to all of them and put some electrical tape over the ends so they don't snag and put the whole shitteroo through at the same time.
ms3js
Jan 21, 2017 01:23 PM
JHC210
2014-2024 Touring Models
13
Mar 6, 2016 06:35 AM
Rodney54
Sep 30, 2014 06:21 PM
Robtarra39
Jan 2, 2012 06:47 AM
danman2540
Nov 27, 2010 10:27 AM
