speedo/tach installation
Old Aug 25, 2011 | 07:09 PM
spiker's Avatar
spiker
Default speedo/tach installation
Just bought one for my 09 Road King,when I hooked it up to the data link connector and turned the ignition switch on nothing happened.It is suppose to calibrate the millage from the original speedometer.Thought it was a return and couldn't be calibrated again so I hooked it to the speedometer plug and turned the switch on and it said No Data.Could the adapter harness that is supplied be defective.Any one else have this problem? Thanks
Old Aug 26, 2011 | 10:06 AM
a34655's Avatar
a34655
If I remember correctly the handle bar run switch needs to be on also.
Old Aug 26, 2011 | 10:59 AM
spiker's Avatar
spiker
I figured it out.I had the data link connector in the wrong plug,the one just under the seat.The correct one is by the fuse box.This speedo/tack is great,and made in the USA!
Old Aug 26, 2011 | 12:47 PM
TUCCI's Avatar
TUCCI
Let's see a pic along with who you bought it from, part# & stuff like that. Oh and if your really feeling like sharing show us how we can hook it up without having to go thru what you did with pics of where you hooked it up to etc....were waitin
Old Aug 26, 2011 | 03:36 PM
spiker's Avatar
spiker
I'm really bad at posting pictures,don't use the plug in under the seat,use the one by the fuse box to calibrate new speedo.l did a search,speedomeyer/tackometer,one member did a great job with pics and explanations.(127 replys to his thread.i paid 269 for mine at suburban motors,it's near milwaukee.
Limit's Avatar
Limit
I was gonna ask you Spiker if you made sure it was the correct plug, but I didn't want to sound stupid.. It's always the stupid things that make a job take 3 times longer than it should.
Tucci: Below is a link to O-Town D's profile, he has pictures of the install. It helped me through it.
https://www.hdforums.com/forum/membe...h-install.html
Old Aug 26, 2011 | 06:57 PM
spiker's Avatar
spiker
Thanks-you sure wouldn't of sounded stupid talking to a dummy like me-sometimes anyways.
Old Mar 15, 2012 | 02:07 PM
kanakattk's Avatar
kanakattk
Limit, Thank you for posting the link to the pic's. It did help
b-rad9704
Aug 23, 2019 01:15 PM
Da-Rza 21
May 10, 2017 08:56 PM
blarg
Dec 19, 2011 08:02 PM
Texas_Campers
Feb 6, 2011 06:13 PM
CANTDR55
Apr 13, 2007 07:57 PM
