Starter Solonoid issues
Old Sep 12, 2011 | 09:14 PM
mbierbac's Avatar
mbierbac
Default Starter Solonoid issues
Just bought a 1994 Heritage Classic. Sometimes it starts and sometimes it doesn't. I can hear the solonoid click once when the starter button is pushed but no enagement or turn over. After several attempts it will start. The lights do not dim so I am assuming the battery must be okay. Does this sound like starter rely, Solonoid, or the starter itself. It is almost like a loose battery connection without the lights going dim.
Old Sep 12, 2011 | 09:41 PM
Eyespy's Avatar
Eyespy
From: Southern California High Desert, here and there....
If all your cables are tight, no loose electrical connection, then you can usually work around this issue for a long while before the starter solenoid or starter motor needs to be replaced. If it's the original, it's about 17 years old and they do go bad in time. The easy work around for now is a simple push button starter solenoid cover, about $14 for a nice chrome one on ebay. In the meantime, you can remove the solenoid cover (3 screws), clean up the copper ring contact on the plunger, make sure the plunger is not sticking. Just pushing in on the plunger like with a screw driver should result in the starter motor engaging and kicking the engine over. The push button allows you this option without removing the cover for those times when the starter just goes "click" and nothing happens.
Old Sep 13, 2011 | 12:07 AM
Bluehighways's Avatar
Bluehighways
Starter Solenoid Contact Disk. Remove, Clean, Replace = Fixed.
Old Sep 13, 2011 | 12:19 AM
D1gger's Avatar
D1gger
Check THIS thread out in the Evo forum, it will get you completely up to speed on the starting issue that seems common to the Evos...
For me what worked was a combination of cleaning the solenoid contacts and ring really well, and cutting the jumper wire between the "Ign" and "Lights" positions on the key switch, so that I can start the bike without all the lights burning up the available current from the battery. I still get the dreaded click every once in a while, but it's pretty rare now and seems to only do it once when it does it...
Old Sep 13, 2011 | 07:01 AM
galtjunk's Avatar
galtjunk
+1
Read that thread.
The addition of another relay with a direct route to the battery solved all of my starting problems.
Old Sep 13, 2011 | 07:15 AM
oldairboater's Avatar
oldairboater
All connections need to be clean and tight. Starter needs to have good brushes. Solenoid must be good. Starters only click when something is wrong.
Old Sep 20, 2011 | 10:30 PM
mbierbac's Avatar
mbierbac
Default Many Thanks
Just wanted to give thanks for a little direction from you guys as to my starter solonoid issue. Instead of buying the push button cover to prolong the agony. I decided to buy a shop manual, Solonoid, and starter relay in hopes that its not the starter. If it turns out its just poor electrical contacts, I guess well at least I have peace of mind in knowing I won't be stranded 200 miles from home(I hope)
Old Sep 21, 2011 | 10:11 AM
the blob's Avatar
the blob
yea i had a ba neg.batt. ground once and it made my bike start and run like it was on crack!
97Heritagerider
Electrical/Lighting/Alarm
Apr 16, 2017 08:26 PM
NB Biker
Aug 23, 2014 06:54 AM
mdunn
Jul 23, 2012 01:18 PM
keith xlcr
Aug 3, 2010 11:12 PM
chopper.stud
Sep 22, 2007 01:10 PM
