It's the bottom part of the HLY-5011 dakota digital gauge but it is not there part.
It has the turn/red/high beam/and neutral. Problem is the neutral light does not light up. I can't figure how to power the bulb as it's too deep and small to see.
I'd like to see who makes this bottom portion?
I've tried grounding the trans switch but no luck. The wire to that switch rotates but playing with it didn't help.
That or time to put a better style of digital gauge on this thing.
It won't come out. The row is glued in and down in some recesses. The circuit board seems to be one piece with all of them and then glued into the housing. All the rest work so I'm not trying to break any more...well, not sure on the red one.
I don't know which wire is for the trans switch. Also not sure how much power to put to them. 12v or less?
Looks like you need to head over to radio shack and pick up 2 resistors to replace the rusty ones. Just bring in the old ones and they can mach them up by the colored bands.
Yup, they don't like 12v. Burnt both turn bulbs. Now only the high works..LOL.
I'll have to get a new board and solder it in or just get another dash without this monkey design. It got water in it because it is not sealed. All it needed was a drain or a rubber seal. Stupid.
The resistors drop the voltage probably to 5V. Radio shack or similar electronics stores should have resistors and LEDs. Desoldering and soldering on a board like that isn't difficult but you may want to attach a "heat sink" to avoid damaging the components.
Also adding a drain hole to the unit should be easy.
