Oil question - HELP please!
Old Dec 2, 2006 | 09:50 AM
britbiker's Avatar
britbiker
Default Oil question - HELP please!
Just bought a 2005 XL883C. Reading thru the Owners Manual it states if HD oil isn't available to use deisel oil!! I have a lot of high quality 20W50 semi synthetic m/cycle oil already in my garage, which was bought for my previous bike - is this suitable or not? Sorry if this is a dumb question!
Thanks.
[IMG]local://upfiles/21509/7BDA8BD161F34704953785EB1B544F61.jpg[/IMG]
Old Dec 2, 2006 | 10:43 AM
dc1450's Avatar
dc1450
Default RE: Oil question - HELP please!
Your oil will be fine. What Harley is saying is that automotive oil designed for gas engines is not as good for your engine. The modern oil had additives/modifiers to maximize fuel mileage and is not sutable for an air cooled engine. The Diesel oil does not contain these additives and is more suitable to use IN A PINCH.
if the oil that you have is the right viscosity (it is) and motorcycle specific then you can safely use it.
DC.
Old Dec 2, 2006 | 10:50 AM
KeithB's Avatar
KeithB
Big Kahuna HDF Member
what kind/brand oil is it?
Old Dec 2, 2006 | 10:59 AM
1flhtk4me's Avatar
1flhtk4me
ORIGINAL: britbiker
Welcome to the forum!
Actually it is not a dumb question,however dont be suprised if someone flames you for starting another oil related thread.
Did you try doing a search??There is also a forum here for oil related questions.There is a ton of info at your reach with the search feature.
Old Dec 2, 2006 | 11:29 AM
pococj's Avatar
pococj
Check here: https://www.hdforums.com/forumid_222/tt.htm Read the reference posts in the top section.
Short answer #1 - The oil you have will work fine.
Not quite as short answer #2 - Any 20w-50 oil will be OK. No 20w-50, or 15w-50, or 5w-50 oil has any gas mileage improving additives, friction modifiers, or anything else that would cause a problem in your air-cooled engine. You do not even need to use motorcycle specific oil, just oil of the proper viscosity.
Old Dec 2, 2006 | 11:41 AM
pococj's Avatar
pococj
Well, I just noticed you are from over the pond. My remarks in answer #2 about the contents of oil additives may not apply to the standards set in your neck of the world.
Old Dec 3, 2006 | 03:56 AM
britbiker's Avatar
britbiker
Thanks for the info guys!
pococj: Just read your write up on oil, comprehensive doesn't describe it! Superb!
Thanks again to all.
Oh, the oil I have is Mobil 1.
Old Dec 3, 2006 | 11:02 AM
Edmo's Avatar
Edmo
BritBiker,
Welcome!
Edmo
Old Dec 3, 2006 | 11:36 AM
britbiker's Avatar
britbiker
Edmo:
Thanks for the link to this site buddy - it rocks!
Cheers, Mike.
Old Dec 3, 2006 | 08:36 PM
KeithB's Avatar
KeithB
Skip those articals on oil and gear oil look good i need to read them over real good, thanks for your efforts
V_twins
Shovelhead
Oct 1, 2020 03:32 PM
joe10softail
Mar 26, 2016 07:50 PM
Jamman718
General Topics/Tech Tips
May 28, 2014 09:06 PM
old skool1983
Oil Archive (no new posts)
Nov 28, 2009 10:12 AM
emoore0023
Apr 2, 2008 11:34 AM
