Another Oil question...
Old Dec 4, 2006 | 09:41 PM
anubisss's Avatar
anubisss
Default Another Oil question...
I live where it is usually between 50 and 80 degress, at least in the winter. Is 15w 40 thick enough for the basic engine oil. I never really considered that this bike is only air cooled. Do you guys think that this is enough protection for the engine. No, it is not synthetic oil...
Old Dec 4, 2006 | 09:48 PM
molsenice's Avatar
molsenice
Default RE: Another Oil question...
pm poccio - man knows oil better than the arabs
Old Dec 4, 2006 | 09:51 PM
Wally's Avatar
Wally
20w50
LRonHoover's Avatar
LRonHoover
In the winter, you can run that 40 wt no problem. Actually it's better in the winter season due to the cold and it makes for easier starts.
My 03 Softail Service Manual says 10W-40 is okay if your lowest ambient temperature goes below 40°F and it has an EXCELLENT Rating for Cold Weather Starts below 50°F. Page 1-11
I used the 10W40 during the winter in Colorado. Worked like a gem
Old Dec 4, 2006 | 10:00 PM
cwilks's Avatar
cwilks
So does 20-50, why would you want to F with something that's been working in these scooters for decades?
Old Dec 4, 2006 | 10:05 PM
molsenice's Avatar
molsenice
here we go again - pm poccio - seriously
Old Dec 4, 2006 | 10:08 PM
LRonHoover's Avatar
LRonHoover
Because when you have very low temperatures, close to freezing and upper thirties, that 50W flows a bit sluggishly when it's very cold and that could lead to more metal wear. Here on the Central Coast, it's been down in the 20's a couple of times. I want to know my oil is going to flow and not sit in the sump like molasses until it heats up.
In the winter, 10W-40 is fine as you don't have the high daily temperatures. It worked on my E84 Evo without any trouble. I had 90K on that motor when I sold it and it didn't have any noticeable wear in the jugs.
Old Dec 4, 2006 | 10:18 PM
cwilks's Avatar
cwilks
It doesn't flow slow enough where you would be able to tell the difference from 40, if you warm the motor up correctly your not going to have a problem. The reason your jugs didn't show much wear was just as much frequency of changing as viscosity. These discussions can go on forever but the fact of the matter is you can use whatever as long as your changing it on a regular basis and not running it low on oil all the time. Guess how I feel about synthetics?
Old Dec 4, 2006 | 10:20 PM
LRonHoover's Avatar
LRonHoover
Ummm.. you don't believe in them?
Yeah, it probably had something to do with those every 2500 mile changes.
But in Jan thru March in Co, I ran the 40W.
Old Dec 4, 2006 | 10:56 PM
Bighorse's Avatar
Bighorse
anubisss...petroleum based oil won't stay in grade & is considered to be obsolete (but you know that). That grade should be fine for the conditions you stated but can't you be persuaded to at least go with a part synthetic?.
falconbrother
EVO
14
Nov 18, 2012 11:13 AM
GARY DYER
Oct 12, 2012 08:16 AM
Dancemax
Apr 3, 2008 08:28 AM
128auto
Oil Archive (no new posts)
Nov 7, 2006 12:43 AM
swomack
Oct 26, 2006 04:04 AM
