stupid question
Old Dec 30, 2011 | 08:56 PM
skratch's Avatar
skratch
Originally Posted by gotnspikes
I put heated inserts in my bar and obviously had to remove and then re-install the grips. If you have stock rubber grips, the left/clutch side will have to be cut off or otherwise removed with other techniques out there.
i just dip the left grip in boiling water for about 30 seconds. loosens up the glue enough you can easily twist it off, and don't have to cut anything.
Old Dec 31, 2011 | 12:02 PM
bra$$monkey's Avatar
bra$$monkey
how exactly would someone dip the handlebars in boiling water?
Old Dec 31, 2011 | 12:48 PM
TwiZted Biker's Avatar
TwiZted Biker
Stock cables are damn good quality actually better than most aftermarket stuff . give yours and good looking over and a bit of lube you should be good . Lot's of info on how to inspect cables and what to look for available add a service manual you'll do fine .
Old Dec 31, 2011 | 10:50 PM
oct1949's Avatar
oct1949
Our bike is going on 6yrs old and 36k,, still has the org grips and cables..
I clean the grips every month or so, and lube the cables every Yr, the grips are still like new and the cables work fine.
Old Feb 7, 2013 | 02:02 AM
gixonek's Avatar
gixonek
Hello everyone.... i just changed the grips on my 06 fxsti. If you guys are talking about the little clips that hold the throttle cables into the housing bein a pain the easiest way to do them is after u get the grip outta the way give each clip a small shot of wd40, hold the switch housing in ur hand and give the cable a little yank...it will come right out, the clip will stay in the cable for you. If ur new cables come with new clips give them a shot of wd and push them.into the switch housing....your new cable will be locked into place and ul never have to mess with those stupid little clips......i know this is an old post,i came across it doing a search, but hopefully it will help someone and keep them from spending a bunch of time messin with them stupid things
eddiepoindexter
Oct 12, 2014 12:07 AM
Nostalgia_93
EVO
Aug 28, 2013 06:23 PM
user_1534GD
Jul 11, 2013 05:38 PM
bigmarc66
Apr 26, 2013 12:52 PM
moneymatts
Apr 1, 2013 08:10 PM
