254e cam no pushrods?
Old Feb 1, 2012 | 10:25 AM
Inspector 12's Avatar
Inspector 12
Discussions about the merits of adjustable vs non adjustable pushrods is like oil discussions, lots of opinions.
I prefer non adjustables in both my stage II 103 and my SE 120R. Non adjustable pushrods don't come loose! One less problem to contend with makes it worth the slight increase in effort to install them.
Old Feb 1, 2012 | 11:04 AM
WIDERGLIDER's Avatar
WIDERGLIDER
After talking with a lot of mechanics and riders, I tend to agree with you on this. It just seems logical to have a solid pushrod in there that you can count on. I don't buy the "gasket" arguement, the heads will be fine, people replace those gaskets and very few issues come up....
Old Feb 1, 2012 | 06:22 PM
HoggyMtnBreakdown's Avatar
HoggyMtnBreakdown
If you use a good adjustable and install 'em right, the jam nuts will not move or come loose. I can tell you with 99.9% certainty that mine aren't going anywhere and the rods themselves are more sturdy than the stock rods. Valve train is as quiet as stock, also. Something you won't likely accomplish with the stock rods when using aggressive cam.
Old Sep 28, 2012 | 08:55 AM
UltraNutZ's Avatar
UltraNutZ
widerglider.. here's my short story.
on my 09 Ultra I was in the same boat as you, never pulled anything apart on an HD motor, much less on a motor that was in warranty. I read and read and read before I decided to tackle the job myself as it didn't seem that difficult. So armed with a printed set of intructions I found here on the forum, my service manual, and parts, I proceeded to break everything down. when I got to the cam chest, my ---hole was puckered to say the least. I said the heck with it and broke it loose. Once inside, it was amazing to me how simple this was to do. Pull the parts, paying attention to detail and alignment and put the new parts in. Easy as pie! Hell now I feel like a seasoned HD mechanic! You can do this, its real easy. The key to it is simple.
1. take your time
2. label your parts
3. when in doubt, jump back on here and ask and someone will answer you promptly
4. and last but certainly not least. DO NOT TRY THIS WITHOUT A SERVICE MANUAL
Harleyvetteguy
Feb 8, 2015 08:03 PM
Stopit
Engine Mechanical Topics
13
Feb 17, 2014 09:20 PM
SmittyFXDL
Mar 19, 2012 06:54 PM
moghue
EVO
Jan 15, 2010 09:45 AM
TBone
Apr 15, 2007 02:37 PM
