Changing cams
Old Jan 15, 2010 | 06:42 AM
moghue's Avatar
moghue
2nd Gear
Default Changing cams
Hello new here and had a couple of question on cams. I am going to be changing out cam bearings on my 1998 wide glide and am thinking i might as well change out my cam and lifters. i have been hearing that the ev27 cam is pretty good for stock engines. will i need to do anything to the heads at all or is it ok to just swap out cams. im only asking because i am on a tight budget right now plus as this bike will be going to my daughter when she turns 18 i realy dont want to go overboard. thanks in advance
Old Jan 15, 2010 | 09:19 AM
miacycles's Avatar
miacycles
The E-V 27 is a bolt in cam, change the cam bearing though and check the rollers in the lifters.
Old Jan 15, 2010 | 09:27 AM
moghue's Avatar
moghue
2nd Gear
Thanks for the quick reply. I thought it was just a simple swap i figured as long as i was changing the bearing i would swap out the cam and lifters since it was apart. should i stick with stock lifters or use aftermarket ones.
Old Jan 15, 2010 | 09:30 AM
miacycles's Avatar
miacycles
Use the Harley "B" models they are all thats available now.
Old Jan 15, 2010 | 09:45 AM
grbrown's Avatar
grbrown
T150vej has kindly explained what B lifters are.
Stopit
Engine Mechanical Topics
13
Feb 17, 2014 09:20 PM
jcb1975@yahoo.com
Apr 4, 2012 11:06 PM
Rhetor
Exhaust System Topics
Jun 29, 2011 04:43 AM
shadylane
Apr 9, 2010 03:17 PM
Grayhawk
Aug 1, 2006 02:22 AM
