Engine problems, please help... getting desperate
Just a few things to consider.
No VOES, using a VT-i, which is a hall effect type ignition, two lobes on the advance cam, equal height and width, trigger the sensor. One wire to each side of the coil, that's it. It's as close to points as it can be without being points.
It DID run on points, though the fact the rear was misfiring and the wide lobe was gapped really wide made me think that replacing it would resolve the issue. Apparently, it didn't, though it was a change I wanted to do initially. Points were because I couldn't afford anything else initially.
Vacuum is plugged, using a Pingel hi-flo petcock, so without a vacuum on that, and no VOES, I capped it securely.
Seems a divide on the cylinders running the same. I'm going to try the following, probably Wednesday, I work late the next two days:
1. Switch out the plug wires front for rear. Being a dual-fire, it shouldn't make a difference which is which, see if maybe the new coil is bad (wouldn't be the first time I've had that happen)
2. Compression test
3. check again for intake leaks
4. check for exhaust leaks
5. possibly step down to a smaller slow jet
When checking for intake leaks you can use water instead of WD-40. Obviously, if it dies, then there's a leak.
You didn't say anything about the coil you are using. Does it match the new ignition system?
Did you make a bracket to help hold the carb up? If it hangs on only the intake manifold, it will eventually cause a leak from all that vibration and weight.
The rear plug was sooty and near fouled, the front was clean and new looking, suggesting to me (dual fire) it was firing on the front combustion/rear exhaust, but not the rear combustion. rear cyl exhaust smelled gassy, front maybe just a touch rich.
I swapped the plug wires, front to rear on the plugs but not the coil, and nothing changed = coil good.
Sprayed the hell out of the manifold with cleaner, no RPM change = no intake leak anymore
So since the points gap was off, and the rotor looked to wobble, I tapped it with a hammer and got it near dead center.
It still runs a bit rough, but the wicked misfire is gone! Front and rear have a slightly different rhythm, each smooth in it's own pattern, I believe it is the normal difference between front and rear cylinders.
With the misfire gone, I can now turn my attention to the carb, will go out this week and try to get it tuned up, I'm not convinced the idle circuit is bad, though I can now see if the mix screw will affect change. I'm not sure a #42 is right, since the straight pipes and small foam air cleaner let it breathe like a screen door, but if the screw all the way in barely causes it to die, a 45 might be too much. a few tuner sites suggested a #44 from Drag Spec?
Thanks for all the suggestions, I'll report back later in the week with the next set of results.
