does anyone know the easiest way to remove turning signal switches to be able to replace with chrome ones? i look at them after taking them apart but i cant figure out how to get to the underside of the switch to pry it off?
on mine i take off the top nut and bottom nut and work the housing off but when i turn it over i see tw0 holding eyes holding them to the underside of the elctrical part of the switch?
If this link doesn't help, go to Harley's website, parts, select your bike, then hand controls. Click on the switch kit to bring it up, then click on the "download instruction sheet".
They snap on and off. They can be a real pain in the *** to do. When I did my wife's Deluxe, I slowly and carefully pryed to old ones off using a small screwdriver. Then installed the new ones by pressing them into place until they "Snapped" in. They pry from the sides of the caps...outward, and then up
You have to remove the switch from the housing to install the switch caps
Post above has link to instruction sheet
TAKE YOUR TIME...they break easily
You must remove the control housings. The switch plates are mounting to the control housings with torx screws. The OEM black switch "covers" must be removed and the silver colored (they are not actually chrome) covers can then be CAREFULLY replaced on to the switch assembly.
Take your time....the new switch covers are easy to break while trying to coax onto the switch assembly.
