Chorme switch housing replacement
Old Apr 13, 2008 | 12:23 PM
scoobydoo1765's Avatar
scoobydoo1765
Stage IV
Default Chorme switch housing replacement
Hello,
I just switched the stock black switch housing to the chrome switch housing and now the bike doesn't start when I hit the start buttong and the turn signals don't work when I use the signal buttons. Anybody have and ideas as to why it isn't working? I replaced and put it all back together like it was before.
Thanks
Old Apr 13, 2008 | 12:32 PM
Ribcracker's Avatar
Ribcracker
Default RE: Chorme switch housing replacement
check to make sure you havent snagged an earth wire. Is it both sides that dont work of just the right hand side one ? I have done sevreal set sin the past and never had any issues so you might just have been unlucky and broke a wire.
Old Apr 13, 2008 | 12:33 PM
Booey424's Avatar
Booey424
I would say take it apart to make sure none of the wires got pinched.Or maybe something got disconnected.I put the chrome switches on my ride,and when I put it all back together the little spring for the start button wasn't on.I had to take it apart again and fix it.
Old Apr 13, 2008 | 12:54 PM
Ribcracker's Avatar
Ribcracker
yep those chrome switch covers done 6 sets now so got the hang of it.
Old Apr 13, 2008 | 01:36 PM
SportyPig's Avatar
SportyPig
Ya got a shorted wire somewhere in all that stuff inside. What a pain that is!! I did the chrome buttons just after I got the bike. Thought it would be a quick cheap upgrade, until I could get the chrome housing. After the install of the buttons. I no longer plan to change the switch housing. Too much trouble, and opportunity to screw something up.
You mentioned that the turn signals don't work. Is that just theright turn signal, or both? If it's both, you might have somehow blown a fuse. If it's just the left, I'd say there is a pinched wire. Do the front turn signals come on as running lights when you turn on the key?
Old Apr 13, 2008 | 01:39 PM
Binny's Avatar
Binny
......................RUT ROW................
ORIGINAL: scoobydoo1765
Hello,
Thanks
Old Apr 13, 2008 | 04:07 PM
scoobydoo1765
Stage IV
They both come on as running lights fine. When I try to use the left or right turn signal buttong it doesn't work. The horn button and the high/low beam button work fine. Then you have the start buttong that nothing happens when you push it.
Old Apr 13, 2008 | 11:07 PM
SportyPig's Avatar
SportyPig
Hummm....I'm 2 floors away from my Service manual. I'll try to remember to lookup the wiring on those circuits.
Old Apr 14, 2008 | 05:04 AM
dbleagle's Avatar
dbleagle
Changed mine... one of my first upgrades.... never had a problem, though I will admit that getting them to set in there right took a little time, but it wasn't a really big deal...
I'd look in the housing and maybe loosen the screw or take it out all together and try the buttons to see if everything works and go from there...
Ya' gotta start somewhere....
Charlie D.
Old Apr 14, 2008 | 11:01 AM
Ribcracker's Avatar
Ribcracker
what year and model bike is it I have the wiring diags for 91-03 if its falls in that range I will see if there is a common wire for those circuits
Billy Blaze
Feb 13, 2015 09:06 PM
scooty
Aug 10, 2013 07:43 AM
zgodwin
Jul 12, 2012 09:32 PM
WhiteHorse
Mar 18, 2012 12:24 PM
AusMongrel
Aug 8, 2010 07:41 PM
