Like a freaking idiot I.....
Old May 13, 2012 | 09:53 PM
Thank you, Veterans !'s Avatar
Default Like a freaking idiot I.....
washed my bike with a power washer today. Now it runs bad. I read that water may have got in the power commander. I unplugged some things and no water came out. Exactly where does the water go? I also just got S&S .510 gear cams put in, so I hope the adjustable pushrods did not loosen? Can ya guys help me with some wisdom??
Old May 13, 2012 | 09:55 PM
Its under my seat.
Old May 13, 2012 | 09:57 PM
dgdamore's Avatar
dgdamore
I'm doubting the water loosened your pushrods.
Old May 13, 2012 | 09:59 PM
Dixie Dreg's Avatar
Dixie Dreg
No way that water did anything to your rods, wheel bearings maybe.
Old May 13, 2012 | 10:02 PM
Yellotang's Avatar
Yellotang
More than likely you got moisture in some of the wiring. Give it time and it should dry out and run ok.
Old May 13, 2012 | 10:03 PM
Other Sheep's Avatar
Other Sheep
Pull the spark plug wires and let them dry or use an air compressor to blow them out. Then let them dry. That will usually take care of it.
Old May 13, 2012 | 10:08 PM
joe.1955's Avatar
joe.1955
Depends on your bike, the Dyna's don't have room under the seat for the PC and the connector is located behind the rear cylinder, the PC under the ECM behind the fuse box.
On softails, the ECM is under the seat and the PC is in front of the rear fender.
Are your ECM and PC under the seat? Look for the connectors into the PC and the ECM.
Pull the large gray connectors and make sure all of the water is out, then coat with dielectric grease and reassemble.
Old May 13, 2012 | 10:10 PM
Foodog's Avatar
Foodog
It happened to me one day with just a regular hose wash. Don't know exactly what they're called but one of the large connectors that hangs outside behind the rear cylinder was full of water. I dried it and filled it with diaelectric grease and haven't had a problem since.
Old May 13, 2012 | 10:15 PM
PigInaBlanket's Avatar
PigInaBlanket
Bull, it is under the seat on my Street Bob.
Old May 13, 2012 | 10:17 PM
joe.1955's Avatar
joe.1955
Fair enough, my Wide Glide didn't have room and the installation instructions had me install it under the ECM.
Looking at his post history, the OP has a 2001 Softail.
