Thread Repair for Heads
Old Jul 29, 2012 | 03:05 PM
Detroit Iron's Avatar
Detroit Iron
Turns out the case is cracked. This is a shop diagnosis, not mine. I imagine the easiest fix is to swap on a used engine? Any input on getting the bike back on the road, cheapest/easiest route would be great. Thanks!
Old Jul 29, 2012 | 03:26 PM
Squirrel67's Avatar
Squirrel67
If you don't mind going through the lower end a good machine shop would have no problem fixing the case. At least you would know what you have.
Old Jul 29, 2012 | 04:36 PM
turbotom1052's Avatar
turbotom1052
have run welded up cases and heads on dragbikes making in excess of 300 hp. As far as thread repairs are concerned i prefer a timesert over a helicoil hands down for higher torque loads, bit if there is cracked cases you need to weld them up first especially if the crack impinges on the tapped area. If you going that far as to weld the cases id suggest welding up the threaded area and re drill and tap to original size.
dhbmedic
EVO
Apr 13, 2014 09:13 AM
Detroit Iron
Engine Mechanical Topics
Jan 25, 2013 09:57 PM
twiceretired
Oct 24, 2011 10:49 AM
Bill C
Exhaust System Topics
May 8, 2010 10:10 PM
Sinn
Apr 26, 2010 07:08 PM
