head Bolt Thread Repair
Old Jun 18, 2012 | 10:48 AM
Detroit Iron's Avatar
Detroit Iron
Default head Bolt Thread Repair
A friend has a '95 Dyna which is blowing head gaskets because of stripped threads for the head bolts. I haven't torn it down yet, so my question is... Is this a common problem, and is it repairable with thread repair kits like Heli Coil?
Any input is appreciated.
Old Jul 13, 2012 | 05:25 PM
grbrown's Avatar
grbrown
I don't know if it is common, but stripped threads can certainly be repaired using helicoils. There are other thread inserts available, but whichever you go with I recommend having them installed by an indy who has the right tools. It is easy to make a mess of installing them.
Old Jul 29, 2012 | 03:02 PM
Detroit Iron
Turns out the case is cracked. This is a shop diagnosis, not my own. In this situation I assume the easiest fix is to just swap on a used engine?
Old Jan 25, 2013 | 09:57 PM
adunn10495's Avatar
adunn10495
Stage II
Default Harley helicoils
NO!!!! I tried helicoils on the threads of my 95 FXDWG and they did not hold. I called my local shop and he told me the same thing. I am going to try a steel insert (time-sert) instead.
Crueltiming
Engine Mechanical Topics
11
May 13, 2019 06:03 AM
owenewowen
Jan 25, 2019 03:29 PM
twism_23
Exhaust System Topics
Dec 13, 2012 07:47 AM
Detroit Iron
Jul 29, 2012 04:36 PM
BigJim8765
13
Feb 8, 2010 12:20 PM
