gas tank
Old Sep 3, 2012 | 06:35 AM
rodney123456's Avatar
rodney123456
Default gas tank
2013 street glide ran out of gas or so i thought got a one gallon gas can put that in got to the station and i put in 4.3 gallons i still have a half gallon of gas in tank but it shut off what is going on here. i have a 2012 street glide that was still running with that much gas is there an adjustment on fuel intake somewhere?
Old Sep 3, 2012 | 06:57 AM
piasspj's Avatar
piasspj
pump in tank prefilter intake punctuation warning stand bike off capitalization fill slowly better than pushing 6 gallons sentence structure helps
Old Sep 3, 2012 | 07:00 AM
rodney123456
ok thanks
Old Sep 3, 2012 | 07:01 AM
rodney123456
just was wondering 2013 stock 2012 has cam and stage 2 filled both up at same time.
Old Sep 3, 2012 | 07:10 AM
spoonie's Avatar
spoonie
Wow!!!!!!
Old Sep 3, 2012 | 07:24 AM
dyna rider's Avatar
dyna rider
Default Usable Fuel
Now you know how much usable fuel is in your tank...
Old Sep 3, 2012 | 07:33 AM
mike5380's Avatar
mike5380
What?
Old Sep 3, 2012 | 07:38 AM
RANGER73's Avatar
RANGER73
It will run out of gas with 1/2 - 1 gallons left. Your suppose to put it on reserve when it starts sputtering and head straight to a gas station. Unless EFI's are different.
Old Sep 3, 2012 | 08:12 AM
oldairboater's Avatar
oldairboater
EFI's have no reserve and only a fool runs out of gas twice with money in his pocket. I know that my bikes will go 167 miles on a full tank. That was the distance we had to go between gas stations. I don't recommend doing that often.
Old Sep 3, 2012 | 08:18 AM
piasspj's Avatar
piasspj
The tank is 6 gallons (actually it can hold a bit more). The intake for the fuel is a prefilter that is on the bottom of the fuel pump. The pump is inside the tank.
It is possible that yours isn't mounted correctly but I doubt it.
More likely is that your 1 gallon can had more than 1 gallon of gas in it (maybe 1.25). Then when you got to the station you stuck the nozzle in the tank. The pump shut off at 4.3 gallons. (You figure that = 5.3 gallons and not 6). You probably could have pulled the nozzle out of the tank a little and added more gas (maybe close to a gallon).
