Thundermax and HD Combo Speedo....
Old Sep 9, 2012 | 02:04 PM
golfblues's Avatar
golfblues
Default Thundermax and HD Combo Speedo....
EDIT: Found the problem. Had to restore the distance to empty feature for 2008 up Softails & Dynas. Had to pull the maxi fuse, do some resets, plug in the old ECU, put the Tmax back & presto, everything now works
Anyone have a problem with a Thundermax & the newer Plug & Play HD Combo Speedos? Mine has a V IN ER error. I tried plugging it into the data link to reset it & it worked for a minute then when back to the error code. Nothing reads on the display except the code but the speedo & tach work. I just installed the Tmax.
83shovelhead
May 22, 2017 03:08 PM
Jerry1834
Nov 13, 2015 08:06 AM
bigblock59
Jan 26, 2013 10:31 AM
grumpy 1962
Sep 23, 2012 11:56 AM
Richking
Jan 1, 2007 12:24 AM
