stating problem 75 ironhead
Old Dec 28, 2012 | 10:02 AM
ole ironhead's Avatar
ole ironhead
Stage IV
Default stating problem 75 ironhead
I have replaced starter and solenoid will start if you jump across solenoid but not with starter button it just whirs when using button any suggestions
Old Dec 28, 2012 | 11:01 AM
Def Mute's Avatar
Def Mute
I'd think it obvious that you have no power coming from the switch to the two smaller wires at the solenoid...
Pull those two wires at the starter solenoid, may be in a single connector not sure, and check with multimeter to be sure the switch has continuity through that circuit. Could be bad switch, broken connection between switch and solenoid, bad ground, etc. No way to tell other than tracing it out. Since it works when you cross over the connectors, some where there is no power either going to, or coming back from the switch. That's where I'd start. Be sure to check your fuses. If that model has a necessity to disengage the clutch, or depress the brake, that could be a source (or lack of) also.
If you would like to speak with some one more familiar with that model, maybe check the Sportster section.
800screws
EVO
59
Dec 13, 2014 11:48 AM
paul0311
Dec 7, 2013 02:30 PM
guitarman023
Aug 12, 2013 07:09 AM
knights
Jun 26, 2013 06:51 AM
TBone2
Shovelhead
Aug 22, 2006 08:25 AM
