Blowing Fuses
Old Apr 14, 2013 | 08:29 PM
Branyon's Avatar
Branyon
Stage I
Default Blowing Fuses
I am blowing the same fuse over and over.. It is the fuse for the turn signals and the speedometer. Any guesses?
Old Apr 14, 2013 | 09:12 PM
tripn88's Avatar
tripn88
Pinched wire somewhere.
Old Apr 14, 2013 | 09:14 PM
dawg's Avatar
dawg
Any recent modifications?
Old Apr 14, 2013 | 09:24 PM
oldairboater's Avatar
oldairboater
If your blowing fuses---find out why. Either something is going to ground or the circuit has increased in resistance for some other reason. You could do more damage than just one wire.
Old Apr 15, 2013 | 12:10 AM
hatchetman's Avatar
hatchetman
Do you have to use the signal's in order to blow the fuse or does it just pop when you power up?
Old Apr 15, 2013 | 12:58 AM
i8avet's Avatar
i8avet
6th Gear
what bike is this on?
Old Apr 15, 2013 | 12:59 AM
Glockmeister's Avatar
Glockmeister
Don't ignore this, find the short. I shorted a wire on a bike once and had a fire after just 2 fuses. No damage, I was on top of it at the time, but panic is a word that might be used to describe my response for the first few seconds.
Old Apr 15, 2013 | 01:06 AM
DonN's Avatar
DonN
I was blowing the fuse that goes to the brake light. Turned out it was in the right turn signal switch. I had changed bars 2 years earlier and guess had pinched it and finally wore through.
hyrax222
EVO
15
Jun 2, 2015 11:54 AM
j88j
Nov 16, 2011 06:28 AM
lowrider610
Electrical/Lighting/Alarm
Apr 25, 2010 11:24 AM
XXXRacing
Aug 13, 2007 11:39 PM
tbro90fb
Feb 10, 2007 07:57 PM
