Electrical system lamp(security system)
Old Apr 20, 2013 | 09:35 PM
Fatbob usmc EOD's Avatar
Fatbob usmc EOD
Check and make sure your headlight is working. That's what made my security light come on. I know it's a fairly new bike but when my head light bulb went out I'd only had the bike about six months. I'm glad it did though since I was able to discover the problem on the way home from work giving me time to get a new one. Instead of the next morning
Old Apr 21, 2013 | 06:49 AM
geezer glide 56's Avatar
geezer glide 56
Originally Posted by mpbrown86
I have a 2013 Heritage classic and today the Electrical system lamp (security system) light came on about 30-45min into the ride. We stopped to do some shopping and it did the same thing on the way home at about the same time.. If anyone can help me out with this it would be much appreciated..
Have you checked to see if your turn signals are working correctly...Also check that your front signal running lights are on...Have you changed a bulb in your signals?
Old Apr 21, 2013 | 07:31 AM
fourhour's Avatar
fourhour
Check your battery connections.
Old Apr 21, 2013 | 11:29 PM
mpbrown86's Avatar
mpbrown86
All my lights are working and i did have a problem about a week after i got the bike on the AUX lights. They ended up having to replace the housing cause it kept blowing bulbs.
Old Apr 21, 2013 | 11:31 PM
mpbrown86's Avatar
mpbrown86
lights working fine, will running with the AUX lights on cause that light to come on?
Old Apr 22, 2013 | 12:07 AM
mpbrown86's Avatar
mpbrown86
Originally Posted by nevil
Since you aren't going to talk to the dealer until Monday, you might as well check to see if it threw any codes.
Just ran codes and got 2 back.. b2262, pn69991-11a. First one i might know the problem after googling it and second is a part # for the BCM.
Old Apr 22, 2013 | 01:22 AM
mpbrown86's Avatar
mpbrown86
just got finished messing with and think the problem might be solved the b2262 is the brake light switch on the front brakes. I had taken the hand grips off to change them, did like the grips changed them back.. the switch wasnt being compressed all the way and a few adjustments and now its working fine for now..
Panhead Al
Nov 13, 2017 08:02 PM
GreatGrandBrother
2014-2024 Touring Models
Jun 1, 2017 08:56 AM
lh4x4
Jun 17, 2010 10:34 PM
Mastif
Aug 31, 2009 03:46 PM
2006 Heritage
Apr 27, 2009 08:53 PM
