cold compression test results
Old May 14, 2013 | 05:33 AM
trnewman's Avatar
trnewman
Default cold compression test results
I just finished installing TW-222 cams and adjustable pushrods. I read that I should perform a compression test so I did yesterday. Here are my results based on the instructions in the service manual:
Front-150, 215 with system relay fuse removed (disables ACR)
Rear-145, 215 with system relay fuse removed
Manual says stock should be 110, and 175 with fuse removed. However, that's with stock cams and a warm engine.
I know I should be happy the numbers on both cylinders match but not sure what else they mean. Are these good numbers? Does this mean my pushrod installation was correct and my timing on the cams were set correctly?
I haven't started the bike since the cam install. I'm going to fire it up today after work and hope everything runs ok. The pushrod install was a PIA. I kept double guessing myself whether or not I was on TDC. Hopefully it'll run...
Thanks.
CanadianHD
Mar 8, 2018 07:44 AM
03dragonRK
Engine Mechanical Topics
Apr 27, 2015 06:29 AM
trnewman
May 14, 2013 03:53 AM
TheBurninator
Oct 22, 2011 11:39 PM
DarkKnight1963
EVO
Oct 30, 2007 05:44 PM
