Grip adhesive
Old Mar 14, 2014 | 06:59 AM
Superfly3176's Avatar
Superfly3176
Originally Posted by QC
Why do you want to glue your throttle grip? I'm confused?
This was my first thought. I was like "Throttle side is he serious?"
Old Mar 14, 2014 | 08:17 AM
89FLHT's Avatar
89FLHT
Always have had good results using Honda grip glue. A little goes a long way.
Old Mar 14, 2014 | 09:49 PM
Az Ace's Avatar
Az Ace
I always use golf club grip tape, I've never had a problem
Old Mar 14, 2014 | 10:25 PM
scott01's Avatar
scott01
Been using hairspray for years
Old Mar 14, 2014 | 11:26 PM
Superrust's Avatar
Superrust
This came up a couple months ago, i noticed cause I needed to put grips on. I used hairspray (extra hold aqua net) and it works great. Obviously don't glue the throttle side..
Old Mar 15, 2014 | 01:18 AM
D_gyver's Avatar
D_gyver
I cant believe no one has said scott grip stick or pro tapper grip glue ive used both pro taper works well on MC scott works on everything from watercraft to Harleys and god cant pull them off and yes you have to glue the throttle side if your using a throttle tube its better to glue it off the bars let it dry you could glue the tube to the bars
Old Mar 15, 2014 | 02:00 AM
DeJavu's Avatar
DeJavu
Thumbs up Try Plastidip!
Originally Posted by just plain john
The throttle stays attached to the bars, the grip is glued onto it. I have Kury Pilot grips, and the contact area to be glued is rubber. It doesn't want to stick to metal and loosens up after rolling on and off the throttle.
Had the same problem with soft grips. Having tried just about every kind of adhesive over the years, in desperation I used a can of Plastidip I had for another project. That stuff really worked good. The grip seems to have stiffened up a little but I'll have to cut the grips off to change them. I'm quite happy!
Old Mar 15, 2014 | 02:09 AM
BootheatsBUGS's Avatar
BootheatsBUGS
I bought the grip lock glue from J&P cycles, so far so good. Lots of the stuff in the tube, I imagine I'll have enough to last for numerous grip changes.
Old Mar 15, 2014 | 02:55 AM
Stubby3492's Avatar
Stubby3492
I have ISO grips. I had the left one pop off on me while I was riding.
Didn't have any glue, so I put a couple of wraps of electrical tape on the bar end and jammed the grip back on.
That was two years ago, and it's still on there solid. I can still remove it if I pull and twist really hard without damaging the grip, but it would never come off by accident.
Works better that glue in my opinion.
Old Mar 16, 2014 | 06:07 AM
oct1949's Avatar
oct1949
+1,,, I done my 4-5 yrs ago and its still good to go... same way I used to do my golf clubs..
tacoma5432
Aug 26, 2012 05:56 AM
straps
Mar 15, 2011 07:03 PM
Kansasjase
Oct 30, 2009 07:05 AM
Beerninja
Mar 9, 2009 11:00 PM
wayne72472
Jan 19, 2009 12:00 AM
