Quick fix!
Old May 26, 2014 | 07:10 PM
bkrhoades's Avatar
bkrhoades
Default Quick fix!
After getting home from camping all weekend, I took off on my 2010 Fatboy. I got about 7mi from home, went to take off from a stop sign........nothing but idle. I broke my throttle cable. So I pushed the bike to the curb, pulled out a pair of needle nose pliers, removed the broken cable, switched over to the throttle off cable, which meant I had to turn the throttle the opposite way to get back home. I had a couple of over revs while shifting, but cruised on back home without a problem. I just got done ordering new cables a few minutes ago from J&P. How many of you have broken a throttle cable while riding, and how did you make it home?
Old May 26, 2014 | 08:08 PM
Bill03E's Avatar
Bill03E
I have done it over 50 miles from home, and pulled the outer off of the cable and used my hand on the bare cable.
Old May 26, 2014 | 08:35 PM
JustaHawg's Avatar
JustaHawg
Something similar, retaining clip that holds the carb needle valve fell off and fixed it with a piece of wire I found in my tool bag. I was in the middle of nowhere in rural WI and it got me 50 miles to home. Just good to know common sense is still alive. Man this could be a separate thread called The Common Sense thread
Old May 26, 2014 | 10:10 PM
08Nighttrain's Avatar
08Nighttrain
I feel very lucky if that's possible when mine broke. I was all ready to go on a ride had done all my checks and after letting bike idol a few I hit gas and snap right in the driveway. I was mad but I guess happy that it was at my home.
Old May 26, 2014 | 11:14 PM
Jbic68's Avatar
Jbic68
I had to use the bare cable trick also so I could get home. Man it's a tricky task but it can be done.
Old May 27, 2014 | 02:46 AM
Todd1113's Avatar
Todd1113
Ever had a clutch cable break? Boy thats a fun ride back, slam into 1st gear and then try not to stop until back home.
Ol skool
Aug 27, 2014 04:12 PM
relli
Aug 13, 2011 01:39 PM
Chaseg08
Jun 25, 2011 11:20 AM
dope_man_21
Screamin Eagle CVO Models
Nov 16, 2008 11:38 PM
firemantom
Jul 12, 2008 08:51 AM
