I have a 2"baffle, slash-down setup on a 2012 Dyna.
Ditto the anti-seize. I used the copper based high temp type. You might also try reversing the baffle so the louvers face the exhaust stream. You just have to notch the end for the locking bolt. I know, it will cause exhaust turbulance, but it quiets the sound and with my 2" baffles I'm sure the backpressure increase isn't a problem. Might be good. I repacked them with Drag Specialties glass which was thicker.
