Pretty simple to get the sound you are after out of an EVO...either convert it to points, or disconnect the VOES at idle...some company used to sell a kit for EVOs that had a switch that mounted on the carb, that disconnected the voes at idle and it was normal off-idle...couldn't be too hard to replicate.
The first beat of the po-ta-to po-ta-to sound sound was created by unburned fuel firing in the exhaust stroke of the front piston by the wasted spark of the old dual fire ignition, when both plugs sparked at the same time. With all Harleys now using a single fire ignition, all we get is a ta-to ta-to sound.
Further compounding the loss of that beautiful sound is more controlled fuel delivery due to fuel injection, but the main reason is the change in ignition. Supposedly, you can run a jumper across your two coils so they fire together and duplicate to some extent the old sound. The Niterider site has a page on that.
Here's good article on what happens with a dual fire ignition on a Harley engine.
Wouldn't you lean towards "too thin of an oil" in those situations? I'm having a hard time envisioning a low revolution being the cause of slip 'n slide on a bearing instead of rolling.
Nope. An unbalanced motor with both rods inline on the crank will beat itself to death unless the idle is set at a certain RPM. If you want to run your idle that low and destroy your bottom end that's fine with me... I hope you do more riding than idling.
Again, has nothing to do with oil pressure or flow. As long as the oil pump on a pan/shovel/evo is primed, it doesn't need that much pressure to operate. It is not really an oil "pump" system but an oil "flow" system.
So this is a serious question from someone that used to build V8's and VW engines for fun.
Why can other manufacturers and earlier eras of HD's pull it off? They were/are inline, shared pin, V twins as well.
None of them can "pull it off". It's harmful to the lower end on all HD's. Does it mean you'll necessarily have problems? Maybe not... but it still isn't good for your motor and you will take life off of the bottom end.
