General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
Here is my .02 Your Harley, along with everyone else stock Harley is inherently lean from the factory for EPA and emissions stuff. So, a first upgrade, FOR ME (remember this is just my free .02 worth) would be to get a power commander, PV or FP to richen up that overly lean mixture. So throwing on a replacement K&N filter, assuming they breathe better and flow more air, you are making the bike a bit leaner. Just food for thought.
+1
Adding a programmer will be beneficial now and in the future, for other mods.
I've done some looking on eBay Canada and Kijiji (http://www.kijiji.ca/), and have, indeed found PCiiis going for CDN$100. But they're all units that have been on H-D touring models, and are tagged as such.
Would these work on my Iron, or should I be looking for something Iron-specific?
Alan, I think since your bike is a 15, there is only a power commander 5 available for yours, I don't think you'll find a 3. You can double check though.
Absolutely right! I just looked at the Power Commander site, and see that the 5 is the model for the 2015 883. Not a problem, as I saw a couple of 5s on offer.
I agree with getting a tuner first and correcting the A/F mixture. A PCV will do the trick nicely, and definitely stay away from the dealer downloads. Second, I don't know what price you are seeing for K&N air filters but they usually run in the $50-$90 range depending on the bike. For a bit more you can get a complete intake (which will include a K&N or alike filter. This will open up the intake and allow the bike to breathe without the existing boxed in filter and poor flowing back plate. Both S&S and Arlen Ness make inexpensive (sub $150) intakes that you can run under your existing cover if so desired. Since you said you will be adding an exhaust system in the future you will have 2 of the 3 pieces to get your bike to stage 1 done already. That is the way I would do it and advise my customers to do it if they are taking the step-by-step approach...Tuner, THEN intake or exhaust, one before the other doesn't matter if you have the tuner...
