Sportster Crisis -
Old Oct 20, 2015 | 07:32 AM
Yankee Dog's Avatar
Yankee Dog
Your original oil leaked into the crankcase past the check ball that is supposed to prevent it from leaking into the crankcase...That is why you only got a 1/2 quart out of it.
Your oil tank is higher than your engine, so gravity will win if the check ball hangs up. Then you added more oil and it is now over filled. Somewhat common problem with sportys. You have a dry sump motor. Oil is not supposed to be stored in the crankcase, but sometimes it leaks into it.
The oil is black because it mixed with the old oil 3 quarts of new oil mixed with 2 1/2 quarts of old oil = dirty looking new oil.
Stop adding issues. Leave the bike alone. Don't modify or ad or change any new parts till you get this sorted out. As mentioned, get the oil level correct. Then figure out why the battery is not charging, then go from there. Don't introduce any more variables till sorted out. YD
Blasta
Flathead
Feb 13, 2020 07:54 PM
evolyn
Mar 26, 2019 05:32 AM
EATMO
Milwaukee Eight (M8)
21
Sep 14, 2017 09:26 AM
PJA970
Oil Archive (no new posts)
Sep 18, 2013 07:42 AM
MarkM
Feb 1, 2009 02:38 PM
