clutch adjustment problem
Old Mar 10, 2016 | 04:56 PM
oldbuck's Avatar
oldbuck
Default clutch adjustment problem
Just spent one long frustrating afternoon trying to adjust the clutch on my 2006 ultra. This winter I had pulled the primary and inner primary to swap out a leaking shifter shaft seal. Everything went smooth till I fired up the bike today and attempted to go for a ride. I couldn't shift into third gear. WTF! Back to the garage for clutch adjustment. Go for another ride, still can't get the damn thing to shift out of second. Back to the garage for another go around with the clutch pack adjusting rod. Still no dice. now I'm starting to panic, thinking I screwed up the reassembly of the primary and clutch components. As luck would have it I noticed the retaining ring that holds the plate where the adjusting rod is, was not snapped in all the way. Popped that sucker back in and now it shifts like a champ. Hope this post helps someone prevent a lot of aggravation.
Old Mar 12, 2016 | 09:33 PM
Backdraft161's Avatar
Backdraft161
Thumbs Up!
SOMERG
May 15, 2017 10:32 PM
'05Train
May 8, 2014 06:59 AM
Velocity1
Jul 28, 2013 08:35 AM
straydog13
Ironhead
Mar 18, 2011 12:41 PM
95_S2
Jun 14, 2008 08:09 PM
