Throttle cable adjustment problem...Help...
Old Mar 16, 2016 | 10:29 PM
AGFazio's Avatar
AGFazio
Default Throttle cable adjustment problem...Help...
I have a 2003 Ultra Classic and I installed new bars, Khrome Werks 2+2 Sweepers. I also installed new throttle cables.
I can't get the throttle adjusted. It won't snap back. I checked the cables, not pinched and no sharp bends. The cables are Barnett brand Stealth series.
I've watched the videos. Did everything they said. Installed as per service manual. Going insane....
Old Mar 17, 2016 | 04:45 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Try loosening both adjusters just a bit, each cable must have a small amount of end play.
Old Mar 17, 2016 | 05:02 AM
Hey Man's Avatar
Hey Man
And they're lubed, right?
Old Mar 17, 2016 | 11:56 AM
chromelens's Avatar
chromelens
My guess is the the friction spring shoe in the throttle housing is out of place or pushed in causing the throttle to stick. Pull the housing apart and make sure the little black shoe under the throttle is in place and the screw is adjusted out.
Old Mar 17, 2016 | 01:20 PM
AGFazio's Avatar
AGFazio
Seems to have worked itself out. Maybe just needed to sit overnight to let cable relax or something.
As for the friction shoe, I don't have that. I have an Ultra with electronic cruise.
Old Mar 18, 2016 | 09:54 AM
Speleo's Avatar
Speleo
Ensure the hand grip did not get any crud under it, preventing the throttle grip to turn smoothly. Ask me how I know to check that.
Bruce
Old Mar 18, 2016 | 04:21 PM
hardheaded's Avatar
hardheaded
make sure your handgrip is not push on the end of the handlebar to far or it will bind on the end of the bar. i went though this years ago and it took alitl=tle thinking before i figured it out. you may even have to loosen the switch housing alittle and move it to. if they are not held together tighly the brake light will remain on.
dragon78
Nov 13, 2019 10:25 PM
bigpappa160
General Topics/Tech Tips
Feb 4, 2016 10:49 AM
maximuswaximus
Jan 21, 2015 12:33 PM
teedub79
May 22, 2013 07:48 AM
