torque wrench extender questions
Old May 6, 2016 | 12:20 PM
Architect's Avatar
Architect
Moment (torque) = Force X Distance
175ft/lbs = 175# X 1 ft
If we assume your torque wrench is 18" (1.5') long with a working maximum capacity of 150ft/lbs:
150 ft/lbs = 100# X 1.5 ft
The mechanism in the wrench is calibrated for this math. If you extend the handle (slide a 3 foot long pipe over it) the mechanism has no way of acknowledging the increase in Distance. It will be easier for you to turn the wrench, but the wrench will register or click at 150 ft/lbs. Yes you could keep turning the wrench after the click to get a higher Torque value, but how would you know what is accurate? You would have the Distance and you know the Torque you are trying to achieve but now you can NOT quantify the Force you are exerting with your arm. You could work it out mathematically, but how do you calibrate your ARM?
Of course I could be 100% wrong, been a long time since I did these kinds of calculations, but I would like to think I remember this right. A loaner that goes up to 175 ft/lbs is the way to go.
Old May 6, 2016 | 01:05 PM
F150HD's Avatar
F150HD
Originally Posted by TriGeezer
Recommendation: go rent, or borrow one.
yea, looking into that for sure. Just not something I use everyday so don't wanna have to buy one. Thanks.
Old May 6, 2016 | 01:55 PM
grbrown's Avatar
grbrown
Cool
Very wise. Read my last post again, regarding the mechanism inside a typical torque wrench. I have been through all this myself in the past - and now have two torque wrenches!
Old May 6, 2016 | 01:58 PM
F150HD's Avatar
F150HD
yea, gonna look for loaner, thx.
Old May 6, 2016 | 01:59 PM
F150HD's Avatar
F150HD
I have three! Just not one that goes over 150. Will look into Autozone (as someone recommended) have checked out loaner tools there before.
Thanks.
Old May 7, 2016 | 08:39 PM
Rdcris's Avatar
Rdcris
I calibrate scales and torque wrenches for a living.
Changing the handle size does not change the capacity of the tool, like others have mentioned. The longer handle just makes it easier to pull at the higher capacities of the tool. I get wrenches in the shop that are nearly 6' long and try to pull 600ft lbs is a bear to do when checking the calibration.
If you added a torque multiplier that would help your situation, but those are usually for much bigger tools.
Like it has been said go and rent one of buy another tool, is your best bet.
sjp3003
General Topics/Tech Tips
Jun 18, 2011 12:18 AM
jaustin87
Shovelhead
Jan 17, 2010 05:00 PM
upirons
Jun 16, 2009 11:26 PM
peddler
Apr 6, 2009 12:03 PM
campdreamer47
Jan 30, 2006 12:50 PM
