saddlebag bracket relocation
Old Jul 16, 2016 | 04:16 PM
dyna2008's Avatar
dyna2008
Default saddlebag bracket relocation
Got home with the parts to insall rearfootboards on my 2016flstc. My problem is i cant seem to figure out these saddlebagbracket relocation things. Nothing seems to lineup right at all. Anybody ever insall these things? They look like they are just too long and i need a spacer or something. If all else fails its going for service Tuesday and ill just let them figure it out. Guess i better buy a service manual too! The directions they provide at the very least s#%k!
Old Jul 16, 2016 | 07:01 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
A Service Manual has saved my *** more than once!
Old Aug 2, 2016 | 04:04 PM
rickyhobby's Avatar
rickyhobby
Stage III
I did this recently and found the same issue. After mounting the footboard mounts (50549-06), the saddlebag brackets mount inside the frame rather than sandwiched between the frame and foot peg mount (aka outside the frame). The saddlebag bracket relocation kit (90238-00) that is 'required' is then too far out, while using the stock brackets (now mounted on the inside of the frame) are too far in. Each bracket ends up being 3/4" - 1" off whichever way. I can see why they suggest/require the relocation brackets, but they are too much offset.
I ended up using the relocation kit brackets and (forcibly) pulling the saddlebag frame/mount outward to line up. Kinda want to make some properly offset brackets...
Rick
Old Aug 2, 2016 | 04:08 PM
rickyhobby's Avatar
rickyhobby
Stage III
And I have a service manual, and it does not cover this issue...
Old Aug 7, 2016 | 10:26 AM
grbrown's Avatar
grbrown
OK, let's start afresh. What parts have you bought, a kit? If so what brand and part number. That way we have a hope of helping you out.
Old Aug 11, 2016 | 04:50 PM
rickyhobby's Avatar
rickyhobby
Stage III
Well for me, it was (all HD parts):
passenger floorboard - 50807-08
passenger floorboard mounts - 50459-06
saddlebag bracket relocation kit - 90238-00
Rick
flipper50
General Topics/Tech Tips
Jul 11, 2010 09:19 AM
peddler
Sep 21, 2009 08:09 PM
miacycles
Aug 30, 2008 08:24 AM
lightmaker
Oct 7, 2007 12:08 PM
Clear Water WI
Aug 16, 2006 12:17 AM
