General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
Okay so I get home from work go out jump on the bike to go for a quick ride ignition turns over slowly, engine cranks over slowly two or three times it backfires I let off the start button hit it again and all I can hear is the starter whine. Any ideas fellas?
Well, what a run around. Put jumper cables on and bike fired right up. Checked and my stator went out. Not charging. Thanks for the replies. I showed 12.6v on my battery sitting and bypassed it being the problem.
You have to check batteries under a load to get a clear picture of what is happening with your battery. If you hook your multimeter up to it and get a good reading then you try to start it and the voltage drops then your battery is not as strong as it initially seemed. Think about it in the sense that it takes very little juice to power the volt reading but a lot of juice to power a starter. I've had some batteries read 12.8v and drop to less than 2v when trying to start. Glad you found your problem though.
