5K service
Old Sep 29, 2016 | 01:55 AM
gusotto's Avatar
gusotto
My o-rings always looked good.
Reused a number of times.
Then after doing an oil change with that "good looking" o-ring, I developed a slight leak.
Drips under the bike when parked.
I changed the o-ring and the drips stopped!
Now I change the o-rings anyway.
That "bad" o-ring still looked good when I removed it but it was still a bother to replace.
Waited until bike was cold. (Sat overnight.)
With new o-ring ready to go in, I did a quick replacement when I removed the plug.
Clean pan underneath to catch the small amount of oil.
The just added that small amount of oil when I was done.
Now I use new o-rings.
They're cheap.
Old Sep 29, 2016 | 06:58 AM
Back-n-Black's Avatar
Back-n-Black
Originally Posted by Larry Davis
Did an online search for a 2017 service manual. Nothing came up anywhere. Can't even find it at the MOCO's website.
I have the 2016 FSM that I need....
Old Sep 29, 2016 | 07:07 AM
lionsm13's Avatar
lionsm13
I use the Dimple magnetic plugs http://www.drainplugmagnets.com/ they have a little o-ring on them but I've yet to ever see one that needed replaced.
Prior to I would change out the o-rings and use a bit of the white sealant as well.
Old Sep 29, 2016 | 12:37 PM
dfwhockey17's Avatar
dfwhockey17
As mentioned, get the 3 drain plug o-rings and replace them, they are cheap. We also use a wrap of teflon tape on the drain plug threads to help seal and prevent any galling. Steel plugs like to cross-thread in soft aluminum!
Old Sep 29, 2016 | 12:54 PM
bluzman24's Avatar
bluzman24
$450.00 is a lot. Save your receipts, if you have any warranty issues in the future you can show that the maintenance was done. Plus having records helps at selling or trade in time.
Old Sep 29, 2016 | 12:59 PM
Layne87's Avatar
Layne87
Not changing the O-rings will void the warranty...
sorry I just had to say that with all the EPA 17 model discussions.
Old Sep 30, 2016 | 01:14 PM
mdm's Avatar
mdm
Several times I've needed to remove the drain plug on a car/truck oil pan. You can remove the fill cap and put the end of a shop vac hose over the hole. The vacuum will prevent the oil from coming out the drain. There's been a couple of times that the engine was over-filled and I used this method to control a partial drain to reduce the level. Had a second set of hands move the hose end off the hole slightly to get some draining started. Once I had drained off enough the hose end went back on the hole until I got the plug back in.
I haven't had to use this on a motorcycle but I don't see why it wouldn't work.
O-rings are cheap.
https://www.amazon.com/11105-Harley-.../dp/B00GWYMNMG
http://www.ebay.com/itm/Harley-David...3D180851948152
Old Apr 6, 2017 | 07:38 PM
eschrader's Avatar
eschrader
Post
Are the oil plug orings part # from HD still 11105? They are $1.08 each from New Castle HD.
What type of oil for the transmission?
  • K&N Oil Filter Black- KN-171B - $8.42 on Amazon
  • 6 qts Mobil 1 20W-50 Full Synthetic Motorcycle Oil - ~$60 at Walmart
  • Transmission oil same as engine? How many qts for 17 SGS?
  • 2 O-rings (transmission and engine drain plugs) HD Part #11105? - $1.08 each
  • Clutch gasket cover? HD Part #17369-06- $4.14
  • 2017 touring service manual HD Part #94000383 - $48.00 one time
$120 the first time with manual, $80 after (not including transmission oil)
fyrmedic790
Jan 27, 2017 10:27 PM
dakotabobcat
2014-2024 Touring Models
May 19, 2014 09:22 PM
meanjean
May 27, 2012 04:14 PM
wrestlerone
Jun 1, 2010 09:18 AM
ehjtej
Feb 21, 2008 01:48 PM
