Swingarm removal
Old Nov 17, 2016 | 03:40 PM
shore's Avatar
shore
Default Swingarm removal
2016 street glide.
I can't get the swingarm pivot bolt to loosen. Hold left side hex and loosen right side bolt. It spins slowly? 1/2 impact, spins slowly.
am I doing something wrong?
Old Nov 17, 2016 | 05:52 PM
shore's Avatar
shore
I guess this is a fight of who lets go 1st. Mine was not having it using the hex. Grabbed both bolts, 1 will break loose. The hex washer doesn't do diddly over the thread locker. Mine was the left bolt. It comes out the left so grabbed the exposed section of pivot shaft, after pulling the mount and bushing, with vice grips and the right came off. Pivot slid right out.
Hopefully, this helps someone.
Old Nov 17, 2016 | 07:37 PM
Max Headflow's Avatar
Max Headflow
If you remove the support bracket you can slide the donut, nut , spacer and shaft out assembled. You're a little screwed if the exhaust system is on and the nut on the right is stuck.. I've pulled the support of the other side and double nutted the free end to hold the shaft. Nut is 1/2 -20..
Old Nov 18, 2016 | 08:26 AM
grbrown's Avatar
grbrown
Are you supporting the weight of the trans? The slightest adjustment to your jack/support may make all the difference in taking the weight off the swingarm axle. I don't recall ever getting it out without using a suitable piece of wood and a mallet.
Old Nov 18, 2016 | 09:09 AM
shore's Avatar
shore
I have the engine pulled to the front with a ratchet strap around the upper jug and the steering neck. Getting the pivot bolt out was easy, getting the end bolts out was the issue. Grabbing the pivot bolt with vice grips held it enough to break loose the right bolt.
Mihail Petev
Oct 15, 2018 02:03 AM
BuckeyeUltra
May 6, 2014 08:04 AM
Gambler72
Apr 28, 2010 06:21 PM
Gambler72
Apr 28, 2010 12:30 PM
