Speedometer Cable Help
Old Apr 27, 2017 | 01:17 PM
jrsmith313's Avatar
jrsmith313
Stage II
Default Speedometer Cable Help
I have a V-Star with a Harley 21" wheel that I just purchased. The previous owner said I needed a Harley
speedo cable to get the speedometer working.
Is there a difference in speedo cables? The current one fits, has a square drive and the needle moves if I manually rotate the cable.
I'm trying to figure out if there is really a difference in cables or if the speedo drive is bad.
Thanks in advance for the help.
Old Apr 28, 2017 | 05:27 AM
jrsmith313's Avatar
jrsmith313
Stage II
Old May 6, 2017 | 11:29 AM
grbrown's Avatar
grbrown
Not sure how to answer your question! That doesn't look like a Harley wheel to me and the brake rotor isn't Harley, nor is the speedo drive Harley IMHO. H-D dropped front wheel speedo drive in the mid-90s, when they went electronic. Disconnect the cable at the speedo end and remove the inner, to check that it is still in one piece. Let us know what you find! I assume the speedo doesn't work while riding?
Old May 6, 2017 | 11:55 AM
multihdrdr's Avatar
multihdrdr
Actually the wheel/hub itself looks like Harley (although flipped Left for Right), but the rotor, speedo drive definitely aren't.
How is that wheel interfacing with the speedo drive?
FWIW, Some HD models used speedo cables up to 1999
Old May 7, 2017 | 09:07 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
You say the speedo works when you turn the cable, well... does the cable turn when you spin the wheel?
The previous owner said you needed a Harley cable to make the system work...I`ll bet it never worked.
I think you have a mismatch of parts...
fredskie
Shovelhead
Jan 19, 2020 10:42 AM
HD4EVR
EVO
Feb 16, 2014 09:27 PM
92oldskoolxlh
May 5, 2013 09:19 PM
Knuck213
General Topics/Tech Tips
Mar 29, 2013 06:16 PM
berndog
Shovelhead
Jul 3, 2012 12:56 PM
