oil change time?
Old Jul 29, 2017 | 07:39 PM
69bigblock's Avatar
69bigblock
6th Gear
Talking oil change time?
Just purchased a 2015 VRod with under 100 miles on it. Should I change the oil and filter as the bike is 2 years old, regardless of the low miles?
Old Jul 29, 2017 | 07:54 PM
Jackie Paper's Avatar
Jackie Paper
I would not be concerned about it. My concern would be is the speedometer/odometer the original.
Old Jul 29, 2017 | 08:02 PM
gusotto's Avatar
gusotto
Should be able to look at the tires to see if the bike has been used.
Old Aug 1, 2017 | 05:44 AM
1340hog's Avatar
1340hog
motor oil turns acidic in aluminum blocks when it sits in a motor after awhile.This is why the moco says to change oil before winter storage.Oil is cheap the bike is not,i would loose it for new.
Old Aug 1, 2017 | 05:54 AM
grbrown's Avatar
grbrown
Wink
Change all fluids and filter, plus brake fluids, give it a fresh start in life. If you intend servicing it, please get yourself a genuine FSM first - it will earn its keep with your first service!
It isn't the first bike with a very low mileage - a little while ago a pre-WW2 bike was put up for sale with 30 miles on the clock - the original owner frightened himself witless on it and, after getting home from the dealer, never rode it again!
Old Aug 2, 2017 | 02:28 PM
dfwhockey17's Avatar
dfwhockey17
Change the oil...
Old Aug 2, 2017 | 04:13 PM
ms5899's Avatar
ms5899
5th Gear
Definitely change the oil and filter. Just to be safe
Old Aug 4, 2017 | 09:40 AM
ozzy49938's Avatar
ozzy49938
I always change the fluids on anything that I buy. Gives me a chance to look for possible problems, run the fluids I like, and have a positive start on my maintenance schedule for the rest of the time I own the machine.
Old Aug 5, 2017 | 09:38 AM
Chriswalden88's Avatar
Chriswalden88
Have to agree. All fluids should be changed regardless of miles. Not only does the oil turn acidic in the sump and tank like 1340Hog said, but it also collects moisture and super saturates. Most people do not ride the bike long enough or hot enough to burn this moisture out of the oil.
Change it.
Old Aug 6, 2017 | 09:38 AM
Spartanden's Avatar
Spartanden
can't add what hasn't been said! better safe than sorry
