1996 Roadking help
Old Nov 11, 2017 | 04:43 PM
clascano82's Avatar
clascano82
Stage III
Smile 1996 Roadking help
Can someone please help! My dad just bought a 1996 Harley Roadking a few days ago. He hit a dip and the bike died out. It sounds like it wants to start but wont turnover. The lights are working still. He put gas in the carburetor and it started up. Thats about all I know other than the fact he has been trying to fix this almost nonstop for 3 days! Any advice or thoughts would be greatly appreciated!
Old Nov 11, 2017 | 07:13 PM
beanoboy's Avatar
beanoboy
Since it started when fuel was added directly to the carb., remove gas line/hose from the petcock and make sure you are getting fuel from the tank. There will be a filter in the tank to check if no gas coming out the petcock...b.
Old Nov 11, 2017 | 08:17 PM
clascano82's Avatar
clascano82
Stage III
Apparently there is no petcock
clascano82's Avatar
clascano82
Stage III
Thank you BTW for the response!!!!
Old Nov 12, 2017 | 07:57 AM
beanoboy's Avatar
beanoboy
Oh ! Sorry ...b.
Old Nov 12, 2017 | 09:03 AM
bustert's Avatar
bustert
http://partsfinder.onlinemicrofiche....ANK%20ASSEMBLY
there should be a petcock and it is vacuum operated so if the line is compromised, fuel will not flow. for a grins and giggles test, use a large syringe with the plunger out, and the tip stuck into the hose to the carb and filled it fuel. if it runs till the gasoline is used, petcock is the issue. if the vacuum line is ok, drain the tank and remove the petcock and check screen and stand pipe for clogging. apply vacuum to petcock diapgram nipple and check for open circuit. personally, i do not use a vacuum petcock but you MUST remember to turn the fuel off when not in use.
now if that doesn't work, look for plugged inlet needle inside the carb.
Old Nov 12, 2017 | 09:28 PM
langwilliams's Avatar
langwilliams
I removed the vac petcock on my fatboy an replaced it with a standard one to take that potential problem out....ethanol is hard on rubber gas lines so I replaced mine every few years...it affects the inside so you won't see it breaking down. you can use a mini vac to put some vacuum on the petcock/fuel valve. probably wouldn't hurt to pull the bowl off the bottom of the carb an look for gunk floating it in.
just plain john
EVO
17
Apr 20, 2018 11:45 AM
Spatzw
Jun 26, 2017 12:00 PM
usdart
Carburetor Related
Sep 20, 2016 05:48 AM
bgh4hrlyd
Exhaust System Topics
Aug 13, 2012 03:22 AM
HarleyMom883
Jul 29, 2010 03:57 PM
