General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
Behind the air cleaner there are two sensors.
One sensor is aatched to the other with e plastic screw. The one that should be attached was loose............ ;-(
Now i connected them together and the proble is solved!!
Machine is running smoothly.
