Brake light issue
Old Aug 19, 2018 | 11:08 AM
pjchops's Avatar
pjchops
Default Brake light issue
Need some help....2007 street glide...my brake lights are constantly on, checked fuses, brake relay and looked at wiring I can see. The directionals work but the hazards don’t, brake lights are constantly on, every so often the fuse box will make a clicking noise, anybody have thoughts on this? Thanks!
Old Aug 19, 2018 | 01:16 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
How did you check the brake relay?
If you are sure the relay is not stuck, disconnect a wire from the rear brake switch, if the brake light is still on, you know the problem is the switch in the right handlebar control.
If the light goes out, suspect the rear brake light switch.
Old Aug 19, 2018 | 04:26 PM
j_bee's Avatar
j_bee
You've got some good advice already.
Also make sure you've no free play in your front brake lever, it doesn't need to be a lot of play to cause a similar issue to what you are experiencing. If you do have any play, hold the lever all the way out and see if the brake light goes out.
Old Aug 20, 2018 | 02:11 PM
pjchops's Avatar
pjchops
Originally Posted by j_bee
you've got some good advice already.
thanks!
Old Aug 20, 2018 | 02:12 PM
pjchops's Avatar
pjchops
thanks, I checked everything except the front brake switch, I’ll do that after work...Thanks for the help, I’ll keep you posted.
Old Aug 20, 2018 | 02:17 PM
Jackie Paper's Avatar
Jackie Paper
This..Real pain to replace since you need to cut it out, solider and shrink wrap and get all that back into clam shell. Cover the tank and fender. Protect the button end with a shim when replacing the lever. You can remove the lever and play with the end to see if it will fix it. Sometimes, the little V spring that hold it in place get moved. But the switch is probably burnt or button end broke.
Old Aug 21, 2018 | 06:23 PM
pjchops's Avatar
pjchops
so everything seems to be working as it should and the brake lights are still constantly on but....they go out when I pull the relay out and go on when I put it back in....when it’s in and I pull the front lever and press the rear lever the lights flicker...I would say it’s a bad relay but I put the starter relay in its place and it still does the same thing
Old Aug 21, 2018 | 07:38 PM
Dan89FLSTC's Avatar
Dan89FLSTC
No, everything does not seem to be working as it should if the brake lights are constantly on...
Do you want to screw around with this forever or do you want to find the problem?
Disconnect the wires from the rear brake light switch and tell us what the results are.
It is not the relay.
Old Aug 22, 2018 | 06:46 AM
pjchops's Avatar
pjchops
I disconnected the rear brake switch, brake lights still constantly on, also rear hazards don’t flash but directional work...
Old Aug 25, 2018 | 03:09 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Hazards and directionals are a complete separate issue, fix one problem at a time to avoid confusion.
If the brake light stays on when the rear switch is disconnected, there is only one way the lamp is getting power, through the front brake light switch...
But before you have a funeral for the switch, make sure it is not just simply stuck.
