General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
I've just completed changing oil in all three holes on my new to me 2011 Softail Deluxe. But one thing pisses me off some. WTF is up with the torque specs in the owners manual for the drain plugs? I torqued them all to 15 ft lbs, which is at the bottom of the torque range in the manual. It felt so tight to me that I checked my torque wrench against another to see if there was something wrong with it. There isn't. Two of the tree plugs ground off a curl off of the new O rings. I don't have any leaks that I can see. I did use thread sealant as extra insurance.
Anyway, just curious what you all are doing about torque specs for your bikes. Do you just use your well calibrated elbow? Are all the torque specs in the repair manual off like this? For sure I don't think they'll vibrate out.
Done venting, Chris-
I use my Harbor Freight 1/4 drive torque wrench. Insure you lube that o-ring and thread sealer is good to use. If you don't lube the rings you stand a very good chance of cutting them.
I dont torque torque the drain plugs. I use a small 1/4 ratchet and dont never hold the end and tighten snug. That is plenty. That slippery oil will add around 30% or more to your torque. So 15 will be closer to 20 with oil on the threads.
If you saw a curl of o-ring, you had the wrong o-ring in there.
Harley's drain plugs are MS o-ring fittings. 1/2 -20 fine thread . But with a steep bevel followed up with a c-bore spotface to clean up.
The proper o-ring actually contours into the bevel and the undercut of the plug.
The washer face of the plug goes metal to metal to the c-bore flat bottom. This provides your torque that any type of actual gasket would not. So plug will never loosen.
I never use a torque wrench since oily threads in aluminum tend to over tighten which when you keep a bike a long time tends to strip threads . I run it up and bump it with a quick jerk.
Proper size o-ring no mater what torque you did does not tear unless it's old or used. Use standard grade soft buna N.
And replace it. They are 20 for a few bucks on eBay. $5 for a 100 but who wants a 100
Good luck
I believe you 30% is way to high. I wish I had my pocket reference to post the correct percentage.Why would moco put a torque on the plugs if as you say it's too much?
An oring without lube has a better chance of getting cut. Why would moco put a torque on the plugs if as you say it's too much? So much disinformation I worked aircraft 40 years, along with automobiles. I have performed all maintenance on the bikes over the years and my torque wrench has never stripped out anything. While ymmv this is plain wrong to promote.
