How do you remove forks from a Heritage Softail
Old Mar 15, 2019 | 09:12 PM
usbigred's Avatar
usbigred
Stage IV
Default How do you remove forks from a Heritage Softail
I just bought an 07 Heritage Softail. I love the bike, but it needs new fork seals. Having never had a Harley before, I bought the Harley shop manual for it. The shop manual is vague in listing and describing the steps necessary to remove whatever parts are needed to get to the the forks. Once I get to the forks, I'm good to go, being that I've rebuilt numerous Showa forks. Does anyone know of a list of the steps as to how to remove the forks or a video showing it. Thanks.
Old Mar 15, 2019 | 09:45 PM
TriGeezer's Avatar
TriGeezer
Are you sure you have the Harley Factory Service Manual? They are usually quite thorough.
Old Mar 16, 2019 | 09:59 AM
YZR's Avatar
YZR
Go to YouTube and use the search function. I got lots of choices by doing so...good luck with your project!
Old Mar 16, 2019 | 10:33 AM
Stopit's Avatar
Stopit
Remove the fender , wheel , axle , remove axle pinch bolt , caliper , break torque on the damper bolts and fork caps , you may have to remove the headlight shroud to access the fork tube pinch bolts on the tree , then slide the forks out .
Old Mar 19, 2019 | 05:46 PM
Hey Man's Avatar
Hey Man
Only thing missing is how to remove the Heritage front fender but that's only 4 bolts. You should be able to loosen the pinch bolts enough without removing the lights and nacell cover.
usbigred
Mar 24, 2019 10:14 AM
usbigred
Mar 15, 2019 08:33 PM
trainedkilla
Sep 13, 2013 07:59 AM
bobbyjoes
Jul 6, 2012 11:55 PM
Stoner
Mar 7, 2010 09:14 AM
