Part identification
Old May 14, 2019 | 09:05 AM
Michael Spry's Avatar
Michael Spry
Stage III
Default Part identification
I'm needing someone to point me in the right direction here. I recently had an air filter backer plate bolt back out and got sucked all the way to the cylinder. The piston was broke in the process. I have it completely torn down, parts have all been completely cleaned and gone through the parts washer. I'm fixing to start re-assembly with new heads, pistons, rings, basically complete top end and oil pump while I'm there. My question is there's a little piece at the bottom of each cylinder right beneath the piston that comes to a point. There's two small bolts that hold it into the case on the lifter side. It looks to me to be something that catches oil to send it to the lifters, but I'm needing someone to let me know. When the piston shattered, it broke this piece as well and I'm needing to order one before assembly. Thanks in advance.
Old May 14, 2019 | 09:08 AM
Michael Spry
Stage III
I guess a little more info would be helpful. It's in an 07 street glide, twin cam 96"
Old May 14, 2019 | 10:04 AM
jp1994's Avatar
jp1994
http://partsfinder.onlinemicrofiche....20OIL%20FILTER
#10 piston cooling jet?
Old May 14, 2019 | 10:07 AM
Michael Spry
Stage III
Yes that's it. I found it online right about the same time you did. Thanks so much for the help.
Scottyxbones
EVO
33
Jul 6, 2019 09:18 AM
Hannibal Smith
Shovelhead
Jul 23, 2018 03:15 PM
2009blackpearle
Engine Mechanical Topics
Jul 1, 2017 11:47 PM
Bagger_Vance
87
Jun 6, 2015 03:24 PM
Mascman
Exhaust System Topics
23
Mar 18, 2013 07:38 PM
