Hello from San Antonio!
I'm actually here because I need help with a stage one kit that I tried to install on my 2019 Street Bob. I ordered an Arlen Ness air cleaner, Rinehart slip-ons, and the SE street tuner. After I get everything installed, I fire it up and take it for a spin, only to find that the bike wants to idle at like 1500 rpms, and when I'm riding, it stays at 2500-2800 rpm no matter what gear I'm in.
I have two thoughts: 1. I somehow have a leak in the new air cleaner, which I can't believe, because I followed the instructions to a "T." 2. Harley's pro street tuner doesn't work with the Rinehart mufflers. If anyone here can assist me in my predicament, I would be forever grateful!!
Nick
Throttle by Wire High Idle Reset For Harleys. To reset your idle setting back turn the ignition switch on for 10 seconds off for 10 seconds (do not start the engine), repeat a total of 4 times. That should reset your original throttle position.
Good Luck!!
when I first start the bike, even after its heated up, it wont idle below 1500 rpm. If I open the throttle maybe 5-10% in neutral, the rpms go up to like 2200, and hang, then slowly come back down to 1500. When I tried rolling it in first through my neighborhood, the rpms stay high no matter what, around 2200 rpms, and when I disengage the clutch, the rpms actually go up! If I open the throttle a little in first gear, then release and leave the clutch engaged, the bike stays at 2200 rpm and basically rides itself. Also, Im dealing with a whole lot of heat coming from the header where it connects to my new rinehart muffler.
help!
