General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
I need to install a solenoid repair kit on my 2000 Springer, and it may involve removing the starter. I understand that some bikes, from 2006 and earlier, you had to take the primary cover off. I wonder if that applies to mine, because it has a 107 CI Screaming Eagle motor and Screaming Eagle six speed transmission (replaced in 2018). Would the primary components also have been part of that renovation, as well as the starter? Once I start the removal process, and the starter is not coming off, will it become apparent that I have to remove the primary cover? Does the starter jack shaft have some kind of clip holding it inside the primary?
I am not looking forward to draining the oil, removing the tool kit, then removing the oil tank in order to allow access to the solenoid. It would be a nightmare trying to install the solenoid repair kit with the solenoid in place, but I may not have a choice. It is a tight fit. Have anyone done this before on a Softail Heritage (2000 Springer) without taking out the starter?
If you can get to the solenoid cover to get it off, what do you have to lose. If it doesn't work out then take your whole bike apart to get the starter out, LOL.
The battery cable contact nut is accessible with the oil tank installed, but the other contact nut is hidden behind the oil tank.
Here is one crazy thought I just had. I want to disconnect the spark plug wires and remove the spark plugs (high compression motor with compression release valves) while I crank the motor and listen to and see what the actual contacts and the plunger in the solenoid are doing. I believe I hear a loud electrical type arcing noise when I crank the motor (about half a second). Those of you who have done some electrical welding would know the noise I am talking about. I will have my fingers away from the solenoid just in case. What is the purpose you ask? Just to confirm my suspicions, and possibly replace the plunger. In the past, I have only replaced the plunger when I found it too tedious to remove everything to get to the solenoid and the contacts were still good. No, this is not the right way to do it, but "that's how I roll."
Thanks for the compliment. Great ideas come from thinking out the box. As I said, I get a loud arcing sound coming from the solenoid. I suspect this is the spark jumping across the contacts perhaps because the plunger is not seated correctly. If it will help me answer that, what is wrong with it?
