87 fxr won’t stay on
Old Nov 26, 2020 | 09:39 AM
Andrew Vosseler's Avatar
Andrew Vosseler
Stage I
Default 87 fxr won’t stay on
So I have 87 FXR and when it’s running it’s at 13 V when I hit the gas it goes up to 14.2 V but then after that once it’s warmed up a little bit the voltage goes back down to 13 V now if I let it sit for a little longer it drops down to 12.4 V and shuts off it also has like a little backfire when it does this and sounds like a misfire but it’s new plugs and coil. Anybody else have anything similar happened, it’s a new stater and voltage regulator not sure what else It could be unless those went bad maybe
Old Nov 26, 2020 | 09:56 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Have the battery load tested.
Old Nov 29, 2020 | 05:28 AM
guido4198's Avatar
guido4198
THIS:
Diagnosis of every "issue" that includes the electrical system should begin with either a load test of the battery, or replacement, just for testing purposes with a battery KNOWN to be good. Notice I didn't say with a NEW battery. A new battery is an unknown. It's unusual, but brand new batteries are occasionally bad. If you're an amateur ( like me) after a new battery doesn't solve the problem... you'll chase the problem with new parts until you finally figure out that the new battery you just bought is no good.
Jason Shawver
Aug 11, 2020 09:56 PM
Rampart1664
Sep 10, 2011 03:04 PM
ccardiff
EVO
May 26, 2009 12:27 PM
harleydad98
Jul 31, 2008 01:15 PM
Qball
Apr 25, 2006 03:31 AM
