Push rod tubes
Old Jan 9, 2021 | 01:32 PM
Cruisineasy's Avatar
Cruisineasy
Default Push rod tubes
I have a '14 SG. 103 Twincam. Trying to figure out how to pull the "clips" on the push rod tubes so I can adjust the rods. Tried a few times, Watched a lot of videos, but none that I have found look like mine. Any suggestions??
Old Jan 9, 2021 | 02:22 PM
bustert's Avatar
bustert
they make a set of pliers that will open up the assy so the clip can be removed. however, i just use a big flat blade screw driver to press down on the collar. one note when installing is make sure the upper tube is homed into the upper seat or the clip will not go in. if possible return the tube to original position, although not that important especially so if you changed the three seals.
youtube has vids
Old Jan 9, 2021 | 03:11 PM
470004's Avatar
470004
https://www.motionpro.com/product/08-0255
Old Jan 9, 2021 | 03:29 PM
chopper_man's Avatar
chopper_man
Why do you think you need to adjust your pushrods? Unless you've had engine work done and they were replaced the factory ones are non-adjustable. Even if you've had them replaced, they don't typically come out of adjustment.
Old Jan 10, 2021 | 05:09 AM
Campy Roadie's Avatar
Campy Roadie
Screwdriver.
Adjusting pushrods is a mechanical aptitude step above that. Proceed accordingly. If your bike is a stock machine, it does NOT have adjustable pushrods.
Old Jan 10, 2021 | 08:12 AM
Taggs's Avatar
Taggs
Like chopper_man, I ask the same question. Why are you having to adjust pushrods? Unless the engine has a history of rebuild best to just leave it alone.
Old Jan 10, 2021 | 02:10 PM
Cruisineasy
Have a bit of chatter. Sounds like adjustment is needed, but also sounds like there is no adjustment on mine. It is bone stock.
Old Jan 10, 2021 | 02:32 PM
60Gunner's Avatar
60Gunner
Good Lord...
Check this out. Most likely where your ticking is coming from.
If those don't do it for some reason, replace the crap lifters with these. The 2313SE is the best. Hard to find right now tho.
Hard to say which is your issue without hearing it in person but the first is quite common.
UFO8MyCow
Aug 28, 2013 09:56 PM
sealdoggy04
Exhaust System Topics
Feb 4, 2013 08:27 AM
munkymark
Shovelhead
Jul 4, 2011 07:53 AM
krh1326
Aug 13, 2010 10:15 PM
bonez
Harley Davidson Videos
Jan 21, 2007 12:36 AM
