75 MPH and it just shut off
Old Jun 16, 2021 | 05:58 PM
Dhill1725's Avatar
Dhill1725
Stage I
Unhappy 75 MPH and it just shut off
Hello, wondering if someone might help. Riding going north on the highway smooth sailing at 75 MPH. First of all, I have a 06 ultra classic. I have full Rinehart full exhaust. Power commander 5, K&N ram cold air, Pulstar plasma spark plugs, and all synthetic fluids (Changed every year). The bike just stopped running on the highway. Pulled in clutch coasted off the highway. Hit the starter button. Did not want to start. Switched off and on - handlebars - and hit the start button. Fired right up. Got it going again. 30 sec later it quit again. Off and on and start button. Fired right back up. Had to do that for four miles to limp it back home. Now, I am not trusting it to go anyplace. .
Please help.
Old Jun 16, 2021 | 06:13 PM
TracerBullet's Avatar
TracerBullet
Welcome to the forum
Old Jun 16, 2021 | 06:14 PM
Notgrownup's Avatar
Notgrownup
Drive 74 mph
Old Jun 16, 2021 | 06:19 PM
Stretchman's Avatar
Stretchman
Check for codes. Sounds like a loose connection somewhere.
Old Jun 16, 2021 | 06:22 PM
bad tappets's Avatar
bad tappets
Check battery grounds, main breaker, ignition switch needs cleaning, chaffed wire under tank. Start it up and shake wiring, switches, grounds etc... until you find the problem.
Old Jun 16, 2021 | 06:24 PM
maugusta1's Avatar
maugusta1
How many miles?
Could be fuel filter problem.
Not sure what code you will get with a restricted fuel filter.
Just a thought.
Old Jun 16, 2021 | 06:39 PM
MURPHCC1's Avatar
MURPHCC1
Welcome aboard from Old Cape Cod!!
Old Jun 18, 2021 | 07:34 PM
Trucky911's Avatar
Trucky911
Change the spark plugs to stock harley ones....
Trucky911
Old Jun 19, 2021 | 08:01 AM
bigal51's Avatar
bigal51
I had a couple friends with that vintage HD, and that problem. Turned out to be a broken wire in a small wire harness somewhere around the throttle body. Good luck.
Old Jun 19, 2021 | 11:11 AM
Mr.Softy's Avatar
Mr.Softy
They all do that
Jchaiyo
2014-2024 Touring Models
Feb 22, 2020 07:52 PM
llesure
May 20, 2012 06:28 PM
PappyUSMC
Oct 21, 2010 07:32 PM
fiveola
Shovelhead
Mar 11, 2009 01:49 PM
