General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
I read on HD's webpage for the defiance grips that they can be removed, but I cant find instructions anywhere. Does anyone know how to remove these? It looks like theres a cap on the end of the grip but it doesn't want to budge
I don't know, it was installed by the previous owner
Do you see brownish goop where the bar meets the inside of the grip? If you took it apart the same way as the throttle side something is holding it. I just find it odd they wouldn't use grip glue on the throttle tube as well.
All my dirt bike had rubber grips..... usually used the white bandage tape and some carb cleaner and slid then in place. Cut them off with razor blade. My Harleys, I just took the clam shell off the controls and pulled grips off. You might try slipping a small screwdriver into the end of the grip and see if you can get some movement. I use Avon grips on mine and have not had any issues. If previous owner used an adhesive, you may have to cut the grip off.
Let us know how this came out.
Even without adhesive the clutch side can be somewhat difficult to remove if you're trying to pull it straight off. Try a twisting motion starting at the inboard side and working your way out. If that doesn't work, insert a small screwdriver between the grip and bars from the inboard side and spray some WD-40 in the gap alongside the screwdriver. Let it soak for awhile, and continue the twisting motion. If reinstalling, clean all traces of WD-40 beforehand.
