Check engine light 2015 Street 750
Old Sep 12, 2021 | 02:33 PM
Ians750's Avatar
Ians750
Stage I
Default Check engine light 2015 Street 750
Bike runs great no issues. Just bought it and the owner said when he put a new battery in the CEL came on. I cant figure out how to reset. Tried the procedure for 16,17 etc wont work. Is the 15 different? Bike only has 1348 miles on it. HELP
Old Sep 12, 2021 | 02:54 PM
pgreer's Avatar
pgreer
I believe with the Street 750 you have to use a scanner to check for Diagnostic Trouble Codes (DTC). On most other HD's you can press and hold the speedo trip button and turn on the ignition to enter the diagnostics to view and clear codes. But I don't think that is the case on your bike. So if you don't have a scanner, you will likely need to take it to a shop that can scan it.
Most tuners, like DynoJet and V&H Fuelpack, will check for DTC's.
Paul
David Michael Funch
May 29, 2017 08:55 AM
VTwinJaxFL
Nov 23, 2015 05:26 PM
twister2gt
Feb 19, 2015 01:39 PM
97FXSTC13
Apr 18, 2014 09:16 PM
Floppy Junk
Oct 2, 2012 07:48 AM
